Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Jan 22 4:32 am)
Freeware 3D Modeling Software Links:
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
"What 3D Program Should I buy?" Not one person here can really tell you what's best for you, as everyone has their own taste in workflow. Try the demo or learning edition of the program you're interested in, this is the only way to find out which programs you like.
Hello VolcanicMink,
Before be in Uv mode, set your viewport with the default settings (3 square/ 3d perspective on the left and 3d uv on top right/2D uv on bottom right)
Click in 3d perspective/ go in poly mode selection/ select all/ unwrap and you should see you UVs appearing in the 2 other windows
Select the 2 D UV port and press "space bar"
You should have your UV viewport open now.
Always in poly selection mode, select and move your UV
Press space bar again and you will be in the 3 viewport display mode.
Hope it helps
Best regards,
When I unwrap, I do not have a square background to refit the pieces to like I see in tutorials. What'd I miss?
