Attached Link: http://www.drgeep.com/p4/sm/sm.htm
*(click the image to view full size)*yes... details above ...
Done for Poser 4 but the idea is the same for all versions of Poser.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Note. The correct way to make transparency with specular is:
Plug the transparency into specular value as well. Do not just turn specular off.
Poser does this because a transparency map can mean two different things.
It can mean:
nothing here at all (plug it into specular value)
something here made of clear plastic or glass (leave specular unmodulated)
If you remove the indicated connection, then even the window panes will bounce light specularly.
The blue box has a surface in the window panes. (The specular wire is disconnected from transparency)
The red box has nothing in the window panes. (The specular wire is connected to transparency)
Here I modulated the blue box so that the window panes are still highly specular, but the blue plastic is not. Yet it has a realistic non-zero amount of shine. It's just very low and very spread out.
If you took that away completely, it would not look real.
I want to add a plane with a pattern to my scene, but I want the pattern to be opaque with the plane itself transparent. Is this possible? PP2014
Eddy
