Tue, Nov 19, 11:53 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 18 10:25 pm)
Subject: Wires, cables, hoses and power lines
moogal ( ) posted Thu, 31 July 2014 at 8:17 PM · edited Tue, 19 November 2024 at 11:36 PM
I've come to the conclusion that one of the biggest things I need to tackle in my work is are things like power lines between buildings, electric cords between electronic devices, various types of hoses...
I've always been able to avoid needing to make those things, handwaved them away or simply hid their absence.  But I can look at many past projects and see how these items would have improved things greatly.  Whether in urban environments or futuristic interiors, there's no avoiding cables and hoses.
And I have no clue how people make them.  Do most people use geometry, such as path extruded cylinders?  Or is this something best faked with clever use of flat planes (bump/displacement+alpha)?  Do people extrude them manually, or is there a procedural tool common to higher-end programs for connecting things?
I know there's a big difference between power lines in a neighborhood and someone spraying a garden hose, but I'm afraid I have no idea how to approach either one.
So many questions...
AmbientShade ( ) posted Thu, 31 July 2014 at 9:23 PM
You can make them as actual geometry or you can set them up a few different ways using trans maps.
The trans mapped method is good for older systems where resources are limited and low poly models are necessary, or video games where the wires and ropes and such are mostly just for decoration.
To model them, you can manually extrude a cylinder in whatever shape you need - but this can be tricky depending on how complex the twists and turns are that you need. If your modeler has curves, then you can extrude along a curve and this makes it much easier and faster to get the shape you need.
Zbrush has several curve tools that will let you create any type of twists and turns you can imagine just by drawing it out. You can lace boots, tie knots, build a ball of string, whatever you need to do. You can even create your own insert brush with a head and tail - for example a power cord, or a zipper - and then draw the curve on your canvas or model and drag it out to whatever length and lay pattern you want. It's also useful for creating belts and straps on clothing as you can have the curve snap to another surface or do all its twists and turns in open space.
~Shane
Cage ( ) posted Thu, 31 July 2014 at 10:00 PM
I use the Extruder Poser Python script I wrote, for this sort of thing.  It's no Zbrush, but it works directly within Poser and it's helped me (I may be its only user :lol:) solve a lot of problems while I develop my own scenes.
The script is discussed beginning toward the middle of this page:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2798819&page=13
The current version of the script is available here (extruder4h.py):
http://www.morphography.uk.vu/~cagepage/looper/loopy.html
bantha ( ) posted Fri, 01 August 2014 at 12:06 AM · edited Fri, 01 August 2014 at 12:07 AM
I do have ZBrush and use it a lot, still for a pipe or a cable I mostly prefer Cage's extruder script. It's great, it works within Poser, it's not really complicated. You should have a look at it.
I prefer real geometry.
A ship in port is safe; but that is not what ships are built for.
-"Amazing Grace" Hopper
Avatar image of me done by Chidori
PhilC ( ) posted Fri, 01 August 2014 at 5:08 AM
All Tied Up may help.
http://www.philc.net/AllTiedUp.php
moogal ( ) posted Fri, 01 August 2014 at 5:29 AM
Wow, Extruder looks like loads of fun!  Going to try this ASAP.
moogal ( ) posted Fri, 01 August 2014 at 5:37 AM
One looks useful for making and the other for controlling?  I'm not doing anything with tentacles...  yet.  Mainly exterior power lines and interior wiring, like speaker wires or AC cables.  I do need something with a welder though, so I'm glad I asked when I did.
seachnasaigh ( ) posted Fri, 01 August 2014 at 6:33 AM · edited Fri, 01 August 2014 at 6:43 AM
*     Extruder* creates a tubing mesh.*
*     All Tied Up* rigs your tubing mesh.  You've probably heard the term EZ-posed.  Same thing.  Besides just rigging the tubing, All Tied Up will also give it "EZ-pose" type dials so that you can control the whole figure from the master section.
     For a welder, rigging the cables (and shielding gas hose, if applicable) will allow you to pose doll and welding stinger/gun.  I used this for the Ghostbusters proton pack cable and for the anti-proton beam it fires.
GB.
cedarwolf ( ) posted Fri, 01 August 2014 at 10:30 AM
Wow!  Gotta keep an eye on this thread.
Miss Nancy ( ) posted Fri, 01 August 2014 at 1:19 PM
congrats cage on new site and thx to host english bob!
