Tue, Feb 18, 3:43 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: Genesis - Hanging Poser
jarm ( ) posted Thu, 18 September 2014 at 3:13 PM · edited Wed, 12 February 2025 at 2:55 AM
I have asked this before (I think) but wondered if anybody had more advice.  when I'm using Genesis 2 in Poser using latest DSON i almost always encounter a unrecoverable hang.  Sub division on or off, doesn't seem to make any difference.  Genesis is in it's own runtime away from everything else and I get no indication that it's going to happen, I can be in any camera angle and sometimes it happens quickly sometimes I can be working for a while before it happens.
Never been able to use it.  I'd like to know if anybody else has had this and if there is a remedy.
icprncss2 ( ) posted Thu, 18 September 2014 at 3:30 PM
What OS and what version of Poser?  P9 and 10 are 32 bit even if you have a 64 bit OS.  It sounds like the dread "library lock".  Sometimes you can get around it by using an external library app like Shaderworks Advanced Library Manager or D3D's library app.
Sometimes even an external library app doesn't fix the issue.
You could try one Netherworks camera manager from RDNA.  Issues with the DSON, Genesis/Genesis 2 and Poser are hit and miss things.  Some users have one issue, others have another, others have none at all.  I gave up after one to many library lock issues.
Truthfully, there is no one remedy.  If you send to SMS tech support they will refer you back to DAZ as DSON and Genesis is their baby.
Sorry, I'm not much help.
hborre ( ) posted Thu, 18 September 2014 at 3:32 PM
Is you library linked or external?  I have found that setting your Library to external from within General Preferences will remedy the problem.  I had similar issues and changing the preferences corrected Genesis 2's behavior.
jarm ( ) posted Thu, 18 September 2014 at 3:51 PM
Poser 2014, 64-bit, 16gb of RAM, Windows 8.1, SSD etc.
LIbrary is external, always has been since the option was there, better workflow with two monitors.
Vaskania ( ) posted Thu, 18 September 2014 at 4:04 PM
Do you have any other plugins/mods installed?
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
ThunderStone ( ) posted Thu, 18 September 2014 at 11:40 PM
Have you installed the latest SR for PP2014?
OS: Windows 11 64-bit
Bryce: Bryce Pro 7.1.074
Renderer: Superfly, Firefly
9/11/2001: Never forget...
jarm ( ) posted Fri, 19 September 2014 at 2:59 AM
Yes latest SR is installed and latest DSON.  I've got no extras other than reality
icprncss2 ( ) posted Fri, 19 September 2014 at 7:48 AM
Did you have this issue with a previous version of the DSON?
If the previous version was working, try rolling back to earlier version.  I've has issues in the past.  DAZ would update the importer, SMS would release an SR and the updated importer wouldn't work.
wimvdb ( ) posted Fri, 19 September 2014 at 8:49 AM
I have the same problem with all versions of genesis, dson in Poser 9 as well as Poser 10/2014
It seems the work fine, then it gets slower and then suddenly the UI freezes. Sometimes it comes back after 10 minutes, but with the next bend it freezes again.
This happens all the time when scenes get more complicated
I have not found a solution for this, so I gave up on genesis
I have no such issues with non-dson figures
