Mon, Feb 17, 7:57 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 1:30 pm)
Subject: "This is not a vailid Poser file"
basicwiz ( ) posted Sun, 23 November 2014 at 7:25 PM · edited Mon, 27 January 2025 at 11:58 PM
Recently, I've been having a problem crop up where items that have worked perfectly well in the past are now failing with the announcement "This is not a valid Poser file."
Sometimes re-installing the item from the zip straightens it out, sometimes not.
I cannot be sure, but think it may be connected to the last SR.
I am running Poser Game Dev 64 on Windows 7 64 bit.
I re-installed Poser to no avail.
Opinions? Advice?
basicwiz ( ) posted Sun, 23 November 2014 at 7:29 PM
Also, I have been unable to save anything from the Pose screen to the Characters folder. Upon reloading the save, I get the above error.
I AM NOT using External Morphs.
hornet3d ( ) posted Mon, 24 November 2014 at 6:00 AM
 Not sure this helps but I have Poser Game Dev SR5 and like you I am running it on Windows 7 64bit.  I have not seen the problem although I doubt I have tried saving from the pose screen since the update.  I have just tried it now and it seems to save and load without a hitch
RedPhantom ( ) posted Mon, 24 November 2014 at 6:22 AM
Site Admin
I got a few of those errors. They were corrupted files in my case. My hard drive was going south. Haven't has issues with saving files.
WandW ( ) posted Mon, 24 November 2014 at 6:44 AM
I'd back up your stuff and do a disk check and surface scan...
basicwiz ( ) posted Mon, 24 November 2014 at 6:56 AM
Turns out I have a Samsung 840 series that has known issues along these lines. Just ordered a replacement.
AmbientShade ( ) posted Mon, 24 November 2014 at 3:11 PM
Thanks for mentioning that Doug. I was just about to get a Samsung 840 series ssd that's on sale right now. The reviews on newegg are pretty high, but I keep hearing about the extremely high failure rates of ssd's, regardless of brand, even tho they've been out for a while now. Think I'll stick with the classic spinners for now.
basicwiz ( ) posted Mon, 24 November 2014 at 3:25 PM
This is the first SSD I've had trouble with, and I own six of the beasts... some over two years old. First hickup. I would encourage you  to move in that direction because they are lightning fast.
hornet3d ( ) posted Mon, 24 November 2014 at 3:27 PM
I have had an SSD for close of four years now and the new ones should be better, most of the brand ones come with a three or five year warranty.  That said they do have a finite life and I have my PC set up so the SSD loads the OS and programs but all the temp files are moved to a conventional drive to reduce the numbers of writes to the SSD.
basicwiz ( ) posted Mon, 24 November 2014 at 3:29 PM
Same here, Hornet.
basicwiz ( ) posted Thu, 27 November 2014 at 9:49 AM
For those who followed this thread...
The problem was, indeed, the Samsung 840 - 256Gb SSD.
I replaced it with a like-sized Critical SSD and all of my slow operations and errors magically disappeared.
Thank God for backups!
hornet3d ( ) posted Thu, 27 November 2014 at 2:08 PM
 That is one to keep in the back of the mind.  I did not think of the hard drive at first and most people say that an SSD is there on minute gone the next.
