Hi there
I think has been covered on RDNA several times,i think is DSON what causing this,I've seen this error several times and can say for sure its the DSON,when you just remove(physical removing from folder and placing the DSON on the desktop)DSON from Python scripts->Addons and try again same pose,load the item etc you will not get same error,I would try remove for time being DSON from the Addons and try again to apply this pose/load the item
In my case some specific poses from Hameleon this error will destroy the pose,I will try to take the picture what I mean
Hope this help
Thanks,Jura
Since installing SR5 for poser 2014 pro i often get the following message when loading an item
Exception in RealityDataModel::addObjects:
the item loads first then that message appears though everything seems to work ok and i cant see anything wrong with whats been loaded any one have any idears??
