Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Can you show the texture?
Sometimes Poser corrupts its texture cache. (This just happened to me this morning). A particular texture was rendering white, but looked normal in the material room preview. This will stay that way even if you restart Poser, because the copy it made on disk is messed up and it keeps using it.
In the Render menu, try "Reload Textures" and see if that fixes it.
As you see the wing material works fine but only the long feathers won´t fit to the lights. Not even when i add the original texture to it agian.
Same problem with the bed sheets.
What´s the problem here? Wrong settings?
