Sat, Nov 30, 10:35 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 29 7:57 am)
Subject: Poser hair maps in Max
3dsolo ( ) posted Sat, 10 October 2015 at 7:42 AM · edited Tue, 20 August 2024 at 6:54 PM
Hello, I would like to know how to import hair textures from poser 14 to Max 16. In the max material editor I’ll bring in the texture and the transparency maps. However, I can’t seem to incorporate the scalp map. This leaves the hair looking more like a cloud on the model’s head. Does anyone know how to do this right?
jura11 ( ) posted Sat, 10 October 2015 at 9:29 PM
Hi there
I often use 3DS MAX,although I'm using earlier 3DS MAX 2014 student edition,but to yours question and query,how you are exporting hair as obj ? Or as DAE etc.? Lastly did you using function or script in Poser Collect scene inventory to folder(this is under scripts->Utility)? If no I would use that and about the hair trans map,this depends on hair,as I've used few hair objects from Poser there,but usually all hair will come with trans map for scalp etc if not check the Texture folder in Poser/DAZ etc Runtime and look for yours hair texture there,there should be trans map for scalp etc
Hope this helps
Thanks,Jura
