Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Haven't looked into this but there's also under props/d3d_scene/ an environmental backdrop as well as other pieces which might work just as well. Under scene is an alternate construct in the folder environments.
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
I personally wouldn't use the default ground plane. I would turn it off & use a high poly square from the primitives folder instead. Default ground plane only has 400 polys where as a high-res square has 4096 polys. I think you'll get crisper results.
Have a creative day!
If you are using Superfly, you need the enclosed feature of the construct (default ground) for Superfly to properly raytrace a scene. BUT as 3dfineries suggested you can ADD the high res. ground plane just for the ground textures (and raise it slightly above the ground of the construct), or import grounds and other props for that purpose.
Boni
"I personally wouldn't use the default ground plane. I would turn it off & use a high poly square from the primitives folder instead. Default ground plane only has 400 polys where as a high-res square has 4096 polys. I think you'll get crisper results."
I'd just like to correct this common misconception if I may. A flat plane consisting of one large polygon will render just as crisply and smoothly as a million polygon plane. Mesh resolution doesn't have anything to do with this. Minimum shading rate and texture resolution are the defining factors for something like this. Texture resolution for obvious reasons, minimum shading rate for less obvious but very important things like shader/image map detail and rendertime micropolygonal subdivision. The min shade rate is basically the detail setting for render. Consider displacement and the profound effect of detail that can be achieved on a single polygon in relation to map resolution and rendertime subdivision for example. The mesh resolution is more important for morphing and smooth bending and non planar real time detail, something that isn't a concern when dealing with a flat plane. Just figured I'd point this out...
W10 Pro, HP Envy X360 Laptop, Intel Core i7-10510U, NVIDIA GeForce MX250, Intel UHD, 16 GB DDR4-2400 SDRAM, 1 TB PCIe NVMe M.2 SSD
Mudbox 2022, Adobe PS CC, Poser Pro 11.3, Blender 2.9, Wings3D 2.2.5
My Freestuff and Gallery at ShareCG
Totally forgot about that, EldritchCellar! So right! Try setting your raytrace light's shadow to Blur .4 Samplese 40-60 and Bias to .2 and see if that helps.
Here 2 YouTube tutorials with tips on the new Ground Plane of Poser11.
Video 5 : Tips on the ground plane
Video 6 : More tips and tricks on the ground plane
Best regards, have fun using Poser11
I wanted to texture the ground plane in P11 and use it for my scene. Oddly, when I did it, I had to shrink it to 11% or so to get a proper scale. And when I did that, the line still showed up in renders. Any ideas on how to fix those?
