Wed, Feb 26, 8:08 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Visit the Carrara Gallery here.
Carrara Free Stuff here.
Visit the Renderosity MarketPlace - Your source for digital art content!
Subject: How to animate clouds
versluis ( ) posted Thu, 11 August 2016 at 1:00 PM · edited Mon, 24 February 2025 at 8:12 PM
I'm trying to animate the clouds in the realistic sky, but I'm confused as to how it works.
On one hand, under Scene - Effects - Atmosphere, we have the Clouds Animation parameter in seconds. At the same time, when I edit the realistic sky and head over to the cloud layer, there are parameter for Movement Speed and Transformation.
So which parameter does what, and how do I get those clouds to move across the sky?
MarkBremmer ( ) posted Sat, 13 August 2016 at 6:09 PM
The default setting on the cloud layer is 3 mph. Push that up to 50 - 100 if you want see some motion.
Bottom line, play around a little bit. I think you'll see how it works. ;-)
versluis ( ) posted Wed, 17 August 2016 at 8:04 AM · edited Wed, 17 August 2016 at 8:05 AM
Thanks for the tip, I've worked it out. Even with the highest setting the clouds still moved very slow, but nothing a little speed-up in a video editor couldn't fix.
https://vimeo.com/178995213
