Sun, Jan 5, 8:04 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 05 6:50 pm)
Subject: DOH!!!
JAFO ( ) posted Tue, 20 September 2016 at 5:13 PM · edited Sun, 05 January 2025 at 7:56 PM
Installed PoserFusion2014 into Max2014, and when prompted for path to poser.exe, I clicked PPro 11 exe by mistake...the plugin wont accept that.... help a brother out tell me how to fix this...
Y'all have a great day.
jura11 ( ) posted Tue, 20 September 2016 at 5:54 PM
Hi there
If you have Poser 11 then you should have PoserFusion,I don't use PoserFusion I rather export as OBJ if I want to render,regarding yours question,did you tried to uninstall plugin or even can you check path of plugin in 3DS MAX,this plugin should be located in 3DS MAX folder("C:Program FilesAutodesk3ds Max 2014plugins) and if this doesn't help navigate to Appdata something like this C:Usersyours nameAppDataLocalAutodesk3dsMax2014 - 64bitENU
Hope this helps
Thanks,Jura
JAFO ( ) posted Tue, 20 September 2016 at 6:45 PM · edited Tue, 20 September 2016 at 6:46 PM
Thanks for your reply Jura. yes I tried uninstall... no joy. looked in user/appdata/max2014 found nothing referencing poser..still stumped.... :(
jura11 ( ) posted Tue, 20 September 2016 at 7:08 PM
Hi there
Can you have look on this
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/3ds-Max-A-quick-way-to-disable-3rd-party-plugins.html
and how to use Plugin Manager
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMax/files/GUID-68E2273A-6E4A-4995-B40E-18D6575E2823-htm.html
And can you try reinstall PoserFusion and remove PzrFor3ds.dlo which should be PoserFusion plugin I think
Hope this helps
Thanks,Jura
