Sat, Feb 1, 4:09 PM CST
Renderosity Forums / Poser 11 / Poser Pro 11 OFFICIAL Technical
Welcome to the Poser 11 / Poser Pro 11 OFFICIAL Technical Forum
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Welcome to the Poser Forums! Need help with these versions, advice on upgrading? Etc...you've arrived at the right place!
Looking for Poser Tutorials? Find those HERE
Subject: OBJ's
arrow1 ( ) posted Wed, 18 October 2017 at 6:19 PM · edited Sat, 01 February 2025 at 4:03 PM
Whenever I import an .OBJ file into Poser Pro 11 I can never find my object in the interface. Can anyone assist me? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Boni ( ) posted Wed, 18 October 2017 at 6:28 PM
If you mean the document window ... make sure that you instruct the obj in the pop up window to be at the center of the scene and place on floor. Hopefully that will take care of it. If the orientation parameters of the obj. still don't allow that ... the best place to look for it is UNDER the construct or ground plane. At least that has been my experience. Do a fly around to find it or use the Auxiliary camera. When all else fails use the posing camera to center on the object and pull back to find the location. I've had to do all of these at various points.
Boni
ypvs ( ) posted Wed, 18 October 2017 at 7:40 PM
They can sometimes be imported in a huge size. Unless you're zoomed out a long way you're looking at the empty core. You may need to set the scale to 10% or less when importing.
Do you get an entry in the props list top- left of the document window or in the hierarchy window?
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
infinity10 ( ) posted Thu, 19 October 2017 at 12:35 AM
If you are using Poser Pro 11, you can specify to import the OBJ as a Poser-size item, then you can see it. If it has normals reversed, and the Parameter dials tab has setting to hide backfacing polygons, it may also cause the imported item to appear invisible in preview textured mode. As already mentioned, huge size would make it un-observable because the cameras would be inside the object. (I also find that if I point to the wrong item during export from my modelling software, I get a OBJ without any geometry.) Uhm, I have also had the odd experience that in some cases, if you don't export an OBJ with Material, the item is invisible in Poser scene.
Eternal Hobbyist
Boni ( ) posted Thu, 19 October 2017 at 6:17 AM
ypvs and Infinity10, these are great insights!! thank you!!
Boni
Miss B ( ) posted Thu, 19 October 2017 at 11:59 AM · edited Thu, 19 October 2017 at 12:00 PM
I often import the OBJs of props I've modeled in Blender, and I've gotten into the habit of unchecking everything except "Place on floor", and then selecting "100% Of standard figure", instead of the default "100% Of original size". That usually does the trick.
_______________
Butterfly Dezignz
arrow1 ( ) posted Thu, 19 October 2017 at 4:54 PM
Many thanks everyone. I did all of the above and set import size to standard.OBJ is now visible! Cheers
