Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Not sure your question is understood correctly, doesn't the disc rotate around its own axis by default, meaning any of them (X,Y or Z)? my guess is that this is something you created in another 3D application? If thats the case its most likely easier to center it there as it probably have a center pivot functionality and then import it again into Poser. If that is not what you are after and want to see how it should be in Poser, you can add a standard Cylinder from the library and look how its done. Basically you want both of the points in the center of the disc with the end point slightly above or below in the Y-axis. So what you do is place the center point where it should be, and then you copy/paste the X and Z values to the end point and just move the Y a bit up or down. I think you have to press the "Align" button afterwards to make sure the axis are correct.
In the Joint Editor,If I want to rotate an spinning disc on its own axis 360 degrees where do I set the Centre and end point.Can anyone give me a screen grab of settings? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
