Mon, Nov 25, 8:28 AM CST
Renderosity Forums / Poser 11 / Poser Pro 11 OFFICIAL Technical
Welcome to the Poser 11 / Poser Pro 11 OFFICIAL Technical Forum
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
banner
Welcome to the Poser Forums! Need help with these versions, advice on upgrading? Etc...you've arrived at the right place!
Looking for Poser Tutorials? Find those HERE
Subject: Cloth room problem
gmm2 ( ) posted Mon, 25 February 2019 at 11:35 PM · edited Tue, 19 November 2024 at 1:46 AM
I've started having an issue with my cloth simulations. My usual process is to import an OBJ and clothify it. But all of a sudden, every time I try to run a simulation, it won't last. The calculation will run normally with no issues, but after the last frame, the object will revert to its normal state, as if it hadn't been clothified. Scrubbing through the timeline reveals it's not animated at all. This has happened out of the blue, even with OBJs I've used before without issue.
Deleting the Poser.ini file did nothing.
Any ideas?
Miss B ( ) posted Tue, 26 February 2019 at 12:33 AM
I suggest, once you've set up the simulation information, that you save the file before running the sim. I thought they had fixed this issue a couple of P11 updates ago, but maybe not.
If you save the file, it will look like it's going to snap back to it's original pose before the sim began, but then it will snap into the pose you set up for it.
_______________
Butterfly Dezignz
gmm2 ( ) posted Tue, 26 February 2019 at 1:34 AM
Thank you! That worked exactly like you said. Weird that it seemed to start out of nowhere, but this is an easy enough fix.
Miss B ( ) posted Tue, 26 February 2019 at 10:46 AM
Glad it worked for you. 🙂
_______________
Butterfly Dezignz
