Sun, Feb 16, 5:25 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Subject: Sticky liquids?
Robert_Ripley ( ) posted Sat, 25 January 2020 at 7:45 AM · edited Sat, 15 February 2025 at 8:24 AM
How to make sticky liquids in poser? i mean i have some 3d liquids (pouring out water for exp.) can i make them stick to an object? like it would pour down?
or second thought kind of manipulation of a skin tight suit with a transperancy map
or can i just make a sphere "ooze down"? and stick it to another object too?
thx :)
FVerbaas ( ) posted Sat, 25 January 2020 at 9:12 AM · edited Sat, 25 January 2020 at 9:13 AM
Forum Coordinator
There is no ready tool for that in Poser. I recall having seen some simulators on the web that could do this, using geometry not far off from Poser's definition method. I lost the bookmarks though.
You may try your hand with Bullet Physics.
FVerbaas ( ) posted Sat, 25 January 2020 at 10:07 AM
Forum Coordinator
ThunderStone ( ) posted Sat, 25 January 2020 at 10:43 AM
Thanks for the tip and link. Going to try it out.
OS: Windows 11 64-bit
Bryce: Bryce Pro 7.1.074
Renderer: Superfly, Firefly
9/11/2001: Never forget...
FVerbaas ( ) posted Sat, 25 January 2020 at 10:59 AM
Forum Coordinator
The examples show how to work with liquids.
ThunderStone ( ) posted Sat, 25 January 2020 at 11:18 AM
That was way over my head... WAY WAY out into Space out... 😆
Glitterati3D ( ) posted Sat, 25 January 2020 at 11:43 AM
If you have Poser 11, I would try the Sag morph brush, using a very large brush and fairly high magnitude
CHK2033 ( ) posted Sat, 25 January 2020 at 12:13 PM · edited Sat, 25 January 2020 at 12:16 PM
Export both items in to blender,(or any sculpting program) push/pull/shape it in sculpt mode to the object then export back to Poser
HP Zbook 17 G6,  intel Xeon  64 GB of ram 1 TB SSD, Quadro RTX 5000
SamTherapy ( ) posted Sat, 25 January 2020 at 1:10 PM
Unless you're animating, I don't see the point in trying to achieve this effect directly in Poser, other than painting something on the object surface and fiddling with Displacement/Normals to get the effect.
Robert_Ripley ( ) posted Sun, 26 January 2020 at 2:36 AM
the evolver looks to difficult for me (looking at the manual) i will stick to the Sag morph brush for now...maybe try blender (which i never used)
too bad you can´t use the morphable cloth animation for that (even without doing a animation at final)
ockham ( ) posted Sun, 26 January 2020 at 7:57 AM
I've done it the way SamT suggests. It's easy to control. Paint a displacement map with the edges blurred, and apply it to the surface. You could even animate it by making the map larger than the surface vertically, then animating the V-offset dial on the image map node.
My python page
My ShareCG freebies
CHK2033 ( ) posted Sun, 26 January 2020 at 11:43 AM · edited Sun, 26 January 2020 at 11:44 AM
On second thought. the 2D way is good also, but it all depends on exactly what it is your doing ? There really isn't just 1 solution for it all, 3 different ways I do that depending on what it is and what its for. 2D paint/then PS for the hanging dripping parts.
Modifying the the part I want to "drip" around another object. (the candle started off as a "normal" candle
Beyond that I really cant suggest a way to do it without knowing exactly what it is. cheers
