Fri, Jan 24, 6:19 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 6:13 pm)
Subject: Best for Animations
arrow1 ( ) posted Thu, 07 May 2020 at 5:50 PM · edited Mon, 13 January 2025 at 2:51 PM
I do not want to start a verbal war here! I would like some information. Is Poser Pro 11.3 OK for rendering animations with figures? Reading various forums it seems to me that a lot of users render their animations in other programs.I have been user Poser since version 4 and DAZ Studio since it conception and Vue Infinite 2016. All of these programs seem to me to handle animated images very slow! If an animation is created in Poser say with La Femme Pro.How do you get the entire animation into other programs>? I know that in the case of Vue a PZ3 can be imported but what about other programs for rendering? I hope this query makes sense? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
WDBeaver ( ) posted Thu, 07 May 2020 at 8:34 PM
When I started animating, I started using Vue as my end stage because it not only produced a much more realistic exterior, but the environment was dynamic. Then there was the fact that Vue has one of the more stable network rendering schemes. I still have far more luck with the rendercows than with the queue manager. When I have Infinite installed, it also permitted me to output renders in layers, so they could go straight into composting.
The reason Vue bogs down when handling Poser animations is that Vue is literally running Poser within itself. That can get to be a big load very fast, particularly with the Poser texture sizes. Re-texturing with Vue assets, or Vue friendly assets, can speed up rendering.
As far as 'other programs', there really isn't one that supports Poser Native formats. You can do FBX, but the caveat there is that the FBX standard has a lot of flex to it. Most animation houses have to write their own exporters because while it gets the geometry and textures and basic animation data, things like morphs or dynamics has to be coded for. Well, aside from Octane for Poser. Iclone with 3DXchange can do some talking with Poser, but what I've used it for is importing the .obj set files, animate a figure through the set, export the bvh, then import it into Poser where the same scene is duplicated, so the Poser figure can move through the set. The importers to Max and LW have been abandoned.
From the little bit of playing I've done yes, you can use Poser to render its own animations. The problem is that most of Poser is still single threaded. The render engines are mostly multi threaded, but things like hair and cloth and physics seem to be single thread, so those can slow down your time per frame.
As for LaFemme. The only Vue that can import her is the for pay versions of Vue, as that is the only one with the latest Poser SDK. You can still import -other- figures with 11.3, but there's something about LF that doesn't play well with the previous Vue Infinite's sdk's. Probably the control chips.
arrow1 ( ) posted Thu, 07 May 2020 at 8:48 PM
Many thsnls for your honest reply.I guess Poser Pro 11.3 and Vue 16 Infinite is still the answer for me! Cheers
arrow1 ( ) posted Thu, 07 May 2020 at 9:08 PM
I wonder if you can export from Poser to Blender? Cheers
wolf359 ( ) posted Fri, 08 May 2020 at 2:40 AM
What is the state of the FBX export from poser.??
If it is as good as the Daz Studio exporter you should be able to get results like this.
No cost to try. ?
https://youtu.be/7hSW7H8RVjY
My website
WDBeaver ( ) posted Fri, 08 May 2020 at 6:21 AM
What Wolf said.
Also, keep in mind that Poser has avoided the encrypted proprietary format nonsense that others have embraced.So from that end, it is easier to write and exporter, as you are dealing with .obj geometry files, and the rest is pretty much text files. The issue there is knowing the gotchas of the software taking the import. That either requires access to the sdk for that information (usually $$$$$), or reverse engineering, which is usually a hassle.
