Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
Possible issues with it taking so long might be poke throughs, the control chips being visible, hide them, too high poly in the jeans and maybe if L'homme's subdivision is on, you might try turning it off. Parenting the jeans shouldn't be a problem.
Did you make the villa one of the cloth sim's collision objects? If so, that would add a lot of unnecessary polys to the cloth sim.
You can substitute a simpler primitive mesh to serve as ground, and/or substitute a duplicate of a chair's surface (for sitting poses) for the cloth sim, then hide the primitives before rendering.
OSes: Win7Prox64, Win7Ultx64
I loaded a Villa which was going to be my setting. Then I loaded L'homme. I wanted to use the jeans on him, which is a prop that you use the cloth room on. I had to move L'homme away from the center of the world to get him where I wanted to be, but the jeans didn't move with him, so I parented them to him. After I got him where I wanted him to be, I posed him by hand. I hid the jeans will doing this, since they didn't follow his movements. After I was done, I thought now to the cloth room. But then I thought "Wait! I think he needs to be in the default pose, so I created a key at frame 28 then went to frame 1 and reset him. Then I set up the simulation. I unhid the jeans and tried to simulate, but it seemed like it was taking to long just on the first step. So canceled and thought, "Maybe I need to hide the Villa". So I did and then tried to simulate again. It got through the first step OK. But then it was slowly going through each frame. Never took this long before. So what am I doing wrong, and how do you work it when you have a scene like this? Thanks.
