Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
The following appears to work:
import poser
scene = poser.Scene()
figure = scene.CurrentFigure()
actor = scene.CurrentActor()
scene.SelectActor(figure.ParentActor())
The default ParentActor value in the () almost always being the figure's BODY, according to the Methods Manual ("the parent of a figure is typically the “Body” actor"). Am I doing it right?
Thanks, yes, I tried that before ParentActor - but for some reason it would not work on my test figures. I had the error message that "Body" was not a findable name for the figure. My guess was then that not all figures have an explicit "Body" as a named item within them.
also remember that there is no explicit naming convention used by modellers, so body could be also be
1. UPPER-CASE
2. lower-case
3. MiXeD-CaSe
it may be easier to define a small function to test for that,
import re
class figureOps:
def test_for_body( self, figure = None ):
if figure:
for actor in figure.Actors()
if re.search('body', actor.Name(), re.IGNORECASE):
return actor
return None
bodyactor = figureOps().test_for_body( scene.CurrentFigure )
if bodyactor:
scene.SelectActor( scene.Actor( bodyactor.Name() )
else:
print( "'Body' does not exist on current figure" )
Locked Out
Someboy the actor often named "Body" can have another name. Try with its internal name, something that is rarely changed if I'm not wrong:
# Retrieve the firgure itself
check = scene.CurrentActor().ItsFigure()
# Look for the BODY actor
body_parts = [actor for actor in check.Actors() if 'body:' in actor.InternalName().lower()]
if body_parts:
scene.SelectActor(body_parts[0])
You may even select ifs hair props... ?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
I have a figure in Poser, and the "Figure | Left Foot" item is currently selected.
How do I have a Python script change and set the current body-part selection to the root "Figure | Body"?
I thought I knew how to have a Python script do this, but it seems not. The code I was using was not giving errors, but was also not doing anything.
