Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 9:06 pm)
Originally, L'homme was a morph of Lafemme. I'm not the creator of this but, it appears that this was the L'homme it worked with. Ohki might be able to help you more. A quick test showed setting that L'homme morph to 1 and copying the joint zones did allow it to fit, but bends caused poke through. It's easily ran through the fitting room though. Just remember to set the L'homme size to zero before starting. Let me know if you need help doing it.
Hi! Was pointed here :)
So, what appears to have happened is - right after I finished the first version of this body suit (back when L'Homme was just a morph for La Femme), I had to take a break from Poser for personal reasons. And because this product is RPublishing, when standalone LH came out, I was commissioned to make a proper version for him, but wasn't very much involved in the release and such because of the personal issues I mentioned.
I'm not sure if something went wrong along the way, maybe the update process hanged, the thing is apparently the update didn't reach clients at the time and I wasn't aware of it :( I'm looking into issuing a proper update with the correct files to the store now. Update contains an extra figure, specifically for LH, in the same folder for the LF version (I made it this way to avoid having a million folders for the thing scattered everywhere).
Should be up in a couple of days, if nothing goes wrong! Sorry about the inconvenience!
Feel free to call me Ohki!
I have this product. It is suppose to work on L'Homme too. The only icon for loading it is under La Femme. The readme doesn't say anything about how to apply it to L'Homme.
I loaded it and conformed it to L'Homme. It didn't fit. I tried adjusting some of the parameters. Didn't work. Tried scaling. Couldn't get it to fit. Found a morph that said L'Homme. Set it to 1. Still didn't fit. Tried deleting the outfit and reloading and then setting the the L'Homme morph to 1. Still didn't fit. Even tried setting L'Homme scale to 100 and tried again. But it doesn't cover everything. Parts of the arms and legs are uncovered.
If I have the suit conformed and try to scale it, it goes bonkers. Just keeps getting bigger no mater which way I move the dial. Shades of Ghostbusters! I even tried just parenting and move into place, but couldn't get everything covered.
https://www.renderosity.com/rr/mod/bcs/bodysuit-for-la-femme-and-lhomme/141069/
Anybody have this product? Anybody know what I'm doing wrong.
