Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Dec 04 2:47 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
I looked up the weathertop .obj and indeed it has a weird setup.
If you think the sheer number of objects is the issue, best try to extract one in a file editor and see if it loads.
Facets are defined in 4 domains instead of the usual 3. The 4th domain 'vc' I could not find a description of. Not sure if this is standard. Some interpreters may simply ignore this extra information but others may get confused.
I collect fun models from a variety of sources. Some are 'Poser-friendly' formats, some must be variously ported, wrangled, re-textured...
I'm used to 'rigged' FBX figures etc giving me a world of woes. Though there are honourable exceptions, FBX may import as 'many' sub-rigs, often intractable. They may 'explode'. They may even be 'invisible', have a shadow but no 'body'.
I never expected to meet 'invisible' OBJs. Hey, they're a 'classic' format: What could possibly go wrong ??
I'd pulled in a very nice DA freebie, a port from decades-old PSP game.
https://www.deviantart.com/quake332/art/The-Lord-of-the-Rings-Tactics-Weathertop-906486860
Quake332 had used Ninjaripper to convert 'Weathertop' scene to OBJ+MTL, latter correctly calling PNG textures. I could see I'd have to extract several transparency masks from their alpha channels. Not a problem. Free Irfan View is your friend....
($$) 3DOC correctly loaded and previewed mesh and textures, though could not grok the alpha channels. I could see where such were pasted onto 'flats'. Classic PropViewer32 correctly loaded and previewed mesh, un-textured, but with transparency masked by those alpha channels. So far, so good.
I imported model to my PoserPro_11.3 at 'ground zero', 100% original scale. Couldn't find it. Scaled all the way up to 100k%, down to 0.001%. Still couldn't find it.
Deleted, re-imported at 'ground zero', 100% figure scale. Couldn't find it.
After scratching my head, I tried to open model in Windows' Paint 3D. Bloop !! "Something went wrong."
Windoes' 3D Viewer was okay, as were Noesis and Open3D Viewer...
Curious, I opened the OBJ in 'WordPad'. It was an unusual format, ~300 mini-OBJs concatenated. I've seen such in free RE 'Recreated' scene mega-ports by DE's prolific Richard Mandel, but his work...
So, I opened the model in ($$) 3DOC, re-saved it.
Now, it imported correctly to Poser, either as %original, or %figure.
Downside was all those mini-OBJs each had their own material call. Although 'Diffuse' loaded, Poser did not recognise the Alpha channel. Fortunately, there were only a dozen or two skeletal trees, scrubby bushes and such, and it was easy to hand-apply their transparency maps. Thankfully, most were near start of material list, as Poser's UI does not work well beyond ~40. I nailed the last few by clicking their flagrant 'flats' in Material Room preview.
Along the way, I saw how to paste transparency calls into MTL. For each alpha mapped texture call, eg
I used Notepad to add...
d 0
Please may we have much longer fields for 'image source' entry ??
A couple of days later, I had exactly the same 'No-See-Um' issues with another nice model, a Quake332 'Ninjaripper' port of dark, brooding forest...
https://www.deviantart.com/quake332/art/Corpse-Party-Blood-Drive-Forest-904875803
Same solutions, albeit for only ~65 material calls, and looks good...
I've no idea why Poser and Paint 3D 'fell over', as my initial suspicion that those ~315 sub-objects were to blame was falsified by the forest's ~65...
