Fri, Jan 24, 1:02 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Forum Moderators: nerd Forum Coordinators: nerd
Poser 12 F.A.Q (Last Updated: 2025 Jan 20 8:00 pm)
Welcome to the Poser Forums! Need help with these versions, advice on upgrading? Etc...you've arrived at the right place!
Looking for Poser Tutorials? Find those HERE
Subject: More than one Dynamic Piece.
arrow1 ( ) posted Wed, 16 February 2022 at 6:17 PM · edited Thu, 09 January 2025 at 10:29 PM
I am wanting to render an animation of a La Femme Pro Figure walking with dynamic hair, two piece clothing top and bottom. Can I include all three items in the cloth room for simulation at the same time? If so can anyone suggest settings as I have never used Poser 12 with the cloth room! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
RedPhantom ( ) posted Wed, 16 February 2022 at 8:21 PM · edited Wed, 16 February 2022 at 8:21 PM
Site Admin
Dynamic hair (strand-based) is not a cloth room item. That you use the hair room for. For the clothing, your best bet would be to set up 2 simulations. You can clothify them both with the same simulation, but collisions between the 2 pieces might not work well. The hair should load ready to sim. You just need to turn on collisions for your figure and clothing and the general collisions. You can then go to animation>recalculate dynamics>All and your computer will run all the simulations in the scene. Warning: this will do ALL simulations for every figure so if you have some others already done you might not want to use that. You can then go have a cup of coffee, possibly in the next city.
For coth simulations, the default dynamic controls usually aren't bad. To change then would depend on what fabric you're simulating. I usually check all three boxes in the cloth simulation setting pop-up window. In the collide against... popup I usually set the collation offset and depth both to 0.1. If you have multiple layers of cloth (such as an overskirt over an underskirt) You need to have the offset and depth of the inner layer (like the underskirt) be larger than that of the outer layer for anything outside the clothing (like a chair) and you want that simulation to run first so set it up first. Usually, work from inside to outside.
in this one, the blue skirt needed a higher number than the white one when colliding with his pants and boots.
randym77 ( ) posted Wed, 16 February 2022 at 10:05 PM
It's best to do each sim separately, at least at first.There will likely be things you want to adjust, and it's quicker and easier to do that if you're running one sim at a time.
Go from inner to outer. If your top overlaps the pants, do the pants first, then the top.
I would do the hair first, just because hair is more likely to have memory issues. The less stuff in the scene, the better. Also, I increase the hair density for the final render (without running the sim again). The results aren't any better if you run the sim at high density, it just takes a lot longer.
If you're not familiar with the cloth room, using the default settings is a good start. I usually reduce the collision depth and collision offset a bit, maybe to .4 or .5.
For this walk cycle, I ran the hair sim first, then ran the cloth sim.
