Forum Moderators: nerd, RedPhantom
(Last Updated: 2024 Sep 07 12:35 pm)
I know have the Dawn runtime loaded but Dawn SE is added to the scene with not textures
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
OK so I am having a senile moment, yes the poses are there I just need to look under the Poses Tab and not the Characters tab.
I still have the issue with Dawn though, no textures loaded yet it loads correctly with Poser 12
hborre posted at 2:06 PM Thu, 30 March 2023 - #4460027
Thanks that worked for linking the runtimes and saved me so much trouble. Now down to the texture issue, sorry but another senile moment. If you select load from the launch pad you get just that and empty scene so no lights either.Have you tried running the 'Link previous runtimes' script under Scripts>Utility?
Sorry I guess I just became excited with my new toy.
Many thanks for your help.
Thanks - next on the list.Customize your Library as below:
Cycles shaders always showed up gray in P12 as well.
Maybe this will work for you too: Create a PoserSurface for Filrefly and attach the texture used for Cycles as a diffuse to the PoserSurface (don't forget to switch the checkbox "Firefly Root" on). Leave the Cycles root untouched. Then the preview will work as well.
Solved it! If you introduce the PoserSurface node to the Material Zones, activate the Firefly Root then go back and reactivate the Firefly Root on the PhysicalSurface, you will get the PhysicalSurface node to preview correctly. At that point, delete the PoserSurface. Do that for all the Material Zones and save the Material Collection.
The P13 materials should use the PoserSurface node for FireFly, and the Cycles/PrincipledBSDF for SuperFly. Miki 4 mats didn't follow that rule and have been changed to be the same as the others. Not exactly sure what happened there, but Miki4 shouldn't use the Physical Surface root at all anymore (except for the lasthes, I believe)Solved it! If you introduce the PoserSurface node to the Material Zones, activate the Firefly Root then go back and reactivate the Firefly Root on the PhysicalSurface, you will get the PhysicalSurface node to preview correctly. At that point, delete the PoserSurface. Do that for all the Material Zones and save the Material Collection.
DCArt posted at 10:31 AM Fri, 31 March 2023 - #4460191
hborre posted at 10:56 PM Thu, 30 March 2023 - #4460161That's very true but I discovered last night that the PhysicalSurface node renders agree with both Firefly and Superfly, a slight difference between PhysicalSurface and Cycles renders. Of course, this is subject to further investigation and testing but there appears to be a simplified way to construct Material Shaders for Firefly.The P13 materials should use the PoserSurface node for FireFly, and the Cycles/PrincipledBSDF for SuperFly. Miki 4 mats didn't follow that rule and have been changed to be the same as the others. Not exactly sure what happened there, but Miki4 shouldn't use the Physical Surface root at all anymore (except for the lasthes, I believe)Solved it! If you introduce the PoserSurface node to the Material Zones, activate the Firefly Root then go back and reactivate the Firefly Root on the PhysicalSurface, you will get the PhysicalSurface node to preview correctly. At that point, delete the PoserSurface. Do that for all the Material Zones and save the Material Collection.
And Tim, thanks for the quick correction.
I have purchased Poser 13 and have installed it set up the UI in the same manner as I had set in Poser 12. I then pointed Poser 13 at my Dawn and separate Dawn Pose runtime folders and the show up but the contents are not listed. They are the same folders I used with Poser 12 but there is nothing there for me to use. What the heck am I doing wrong.
