Forum Moderators: nerd, RedPhantom
(Last Updated: 2024 Nov 26 6:49 pm)
RedPhantom posted at 5:31 PM Sun, 4 June 2023 - #4467153
Y-Phil posted at 4:19 PM Sun, 4 June 2023 - #4467150Thank. And indeed, it was feeling at first, tooThat looks awesome. The original, with the smaller smoke texture made me think of magic pouring outOk: two vertical smoke objects, with small differences in their parameters + vertical orientation, a witch, and now I'm happy with the result
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
hornet3d posted at 4:26 AM Tue, 6 June 2023 - #4467285
ghostship2 posted at 11:54 PM Mon, 5 June 2023 - #4467266I appreciate all the kind words!Beautiful.Another Kitbash
What units are you using, I made the shader and my clouds preview looks nothing like the one shown here, it's much larger.Volumetric smoke exhale
Consider me insane if you wish, but is your reality any better?
bwldrd posted at 8:34 PM Tue, 6 June 2023 - #4467345
ghostship2 posted at 10:01 AM Sun, 4 June 2023 - #4467112FeetWhat units are you using, I made the shader and my clouds preview looks nothing like the one shown here, it's much larger.Volumetric smoke exhale
but you have to play with the scaling anyway depending on your model. You'll also want to play with the amount of light coming off it. I have it set that way here because it was hard to see the smoke with the lighting in the scene
After tweaking a number of old space craft and locations to work in Poser 13 and rendered using Superfly I decided to have a go at an outfit.
The outfit in question is Complicated Eve by Uzilite which I purchased way back in April 2010. It was created as a conforming set of items for V4 and here is used on Dawn SE.
Smoke on the Water... and on the Pinup...
Definitely, I love those smokes effect
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Thanks for the update Thalek. Much appreciated.
_______________
Antonia and Apollo would like to thank this thread for teaching me about scatter volumes.
Freddy Mercury would probably say something like "Kind of magic"
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I love the fact that Poser is now fast enough to use it. You can even use volumetrics and DOF and not have a week-long render.
Not to change the subject from volumetric lighting...
I have been playing around with point style lights in Superfly, and I think the results are pretty good. There are three of these lights in this scene. 2 squares, and a ball.
This is how you do it.
Apply this shader to a prop, and use it as a light. You could think of this as an area light, but it has some major differences.
Value 2 in the Cycles Math node is the cutoff distance of the light. I have no clue what the settings are (metric, imperial, etc) And it does not seem to match any of the default Poser UI settings.
Blackbody is the lights temperature, based on one of Planks Law's. You can substitute a color for this as well. IE: for a specific color light you want that blackbody can not produce.
The transparency node is technically not needed and is more of a place holder if you decide to stack multiple emitters onto the same prop. Still experimenting with that, with questionable results.... Not having the transparency node will still default to zero, which is basically the same thing. It just makes more sense to have the transparency node there.
The lightfalloff node is what controls the distance curve of the emissions, brightness, and smoothness. It doesn't work the way you would first think it does either. Experiment and see for yourself.
Strength is not in watts, lumens or any setting you are used to, it is just a strength output that does not calculate anything based on other settings, sizes, etc... A small emitter may need to be set in the 1000's. A large one may never be set much past 1. Smaller emitters will take far longer to clean up as well. (Still missing light portals to deal with that)...
You can change what type of light falloff you want simply by plugging it into the Emissions Strength. And again, your not going to get what you first might assume.
Smoothness is a double edged sword, and takes some experimenting. Small emitters that use smooth may take far longer to clean up, so leave that at 0 for small ones. On larger emitter lights, smooth will crush the lighting and dull blowout if it is a bright light. It works a bit differently in Cycles, and on a different scale. So you may have to play with that versus what you get in Cycles.
Some of this can be applied to actual Poser lights in Superfly, some of it can not and has to be done this way.
And lastly, yes, that is LaFemme again.....
Some things are easy to explain, other things are not........ <- Store -> <-Freebies->
What a wonderful atmospheric scene and a great mix of content to give such stunning detail.Thanks to everyone contributing to this thread. In addition to all the amazing renders there is also much to learn! Here's my take with the scatter volume using Afrodite-Ohki's cube and lights from the LevelUp expansion. Flink's sky, ShaaraMuse3D's scenery, Ken _Gilliland's birds used.
Beautiful work!
I wish I'd been feeling better so I, too, could have been experimenting with volumetrics.
Wow... awesome scene 🤩❤
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
More doodles.... Full size is in my gallery....
Great picture as well ❤
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
From back to front, let's add a studio backdrop, a smokey cube, Poser's one-face square, facing the backdrop, a pinup, a sphere (not visible in the camera), using @shvrdavid's implementation of Firefly's point light kind.
That leads from this:
To the kind of portrait I ignore we could create using Poser: a way to control the quantity of light on only some parts of a character:
Woah.. I'm in love. Thank you so much @shvrdavid
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Playing with Superfly Studio from RPublishing and Blackhearted.
I don't think I want to go in there alone
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
shvrdavid posted at 10:02 PM Wed, 14 June 2023 - #4467954
Y-Phil posted at 3:14 PM Wed, 14 June 2023 - #4467921
Shh, someone will hear us......"Smoky mathematics": AppleJack + ShvrDavid = gloomy passage
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Y-Phil posted at 3:14 PM Wed, 14 June 2023 - #4467921"Smoky mathematics": AppleJack + ShvrDavid = gloomy passage
Wow, fantastic atmosphere, going to try smoke/steam next!
Thank you
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
My first render with Poser 13. I like the Superfly. I've been using Poser since version 2, and the improved render quality and ability to use the GPU just adore me.
It is a very simple rendering. It doesn't have any mystery, but I think it has a lot of future.
I want to take advantage of asking a question: My computer is an Intel I7 6800 with 32 mb of Ram and an Nvidia GTX 1080.
If I upgraded to an I9 with an Nvida 4090, would render times drop dramatically?
Cool render.
A 4090 is far faster than any GTX card, by about 3.5 times in most benchmarks that render. RTX cards can also render in Optix, which can be much faster than CUDA.
Exactly how much faster really depends on what your rendering thou.
I have a 2060 in this system and want to get a 4060ti 16 gig card to render when they come out, just for the memory capacity and the speed it will render in Optix. GPU memory is a bit more important to me than going all the way to a 4090 for the speed advantage that draws 400+ watts and runs me out of the room from the heat output.
You also don't need an I9 to do GPU renders. I went with an I5 13600k processor for the power savings. It has 20 threads and sitting here typing to you the processor is using very little power jumping between 6 and 15 watts. I and drops to 4.3ghtz under full load of about 170 watts. If you do cpu intensive stuff an I9 is a great processor, but it is also a power hog.
Speed is great if you need it all the time. But it costs far more to run it in the long run.
RedPhantom posted at 5:33 PM Sun, 4 June 2023 - #4467154
Absolutely beautiful one, the only slight detail: she hands her microphone like... an icecream,but you may also argue that I never sing so... so that you could also be 100% right on this
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
