Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Attached Link: www.soft-rabbit.com
I've been made aware of a problem with WarriorDL's Polyette figure, where Maconstructor refuses to copy any Vicki morphs on its default settings. The problems are caused by a bug in the Polyette.cr2 file, which still contains the set of original P4 head morphs - if you open it in Poser, you will find that none of them work (you can set the dials, but they cause nothing). The PC MorphManager simply ignores this and copies the Vicki morphs straight into it, but Maconstructor gets confused and believes that the Vicki morphs are the ones that won't fit. An immedate fix would be to set Maconstructor's preferences to "copy incompatible morphs" and "replace existing morphs", which makes it copying like the PC tool, but might leave you with a mixture of working/non-working ones as well. A better (permanent) solution goes like this: 1) open the original Polyette.cr2 in Maconstructor 2) select all head morphs by the "Select" button/popup 3) click "Delete" 4) save the file Depending on your settings, it will either overwrite the original file or create a new one - in any case, dispose of the original .cr2 and backup the new file for future adventures. Now you should be able to copy any set of Vicki head morphs into it. Cheers, MartinC
