Sun, Jan 26, 2:35 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 26 2:05 pm)
Subject: HELP
SCORPIO-69 ( ) posted Sun, 08 July 2001 at 10:14 PM ยท edited Sun, 26 January 2025 at 2:35 PM
i know poser is good program but i cant use it very well .its little hard untill i learn to unloack all its secret. i need answer for 2 question 1: i cant open 2 figures on the same window in poser 4 anyone can tell me how to open 2 figures on the same window ??is that possible or not ?? 2 : how du u apply clothes to a figures or props i cant do that too?? thx very much
Styxx ( ) posted Sun, 08 July 2001 at 10:34 PM
ok, after you open the first figure, to get the second figure. select the figure you want and click the double checkmark. That's how you get clothes in too... to conform the clothes, select the coth item and go to the figure menu. click "conform to" and in the popup select the figure you want the clothes on :) Hope that helps... Styxx
Marque ( ) posted Sun, 08 July 2001 at 10:39 PM
Chapter 3 in the manual is a fairly good tutorial on that but to get you started quickly, after you load the first character, use the double checkmarks at the bottom of the library to load the second character. That way you don't replace the first one. Just highlight the picture of the character and hit the double check mark. To apply the clothing, highlight the picture, his the double checkmark to load it in. Then go to the menu at the top and choose Figure > conform to and a dialog box will open. Choose the figure you want to apply the clothing to. As you add more clothes they will typically be called figure 2 figure 3 and so on, because figure 1 is usually the first figure you loaded, your character. Sometimes they will have a name instead of figure 1. Just choose the character and the clothing should conform to them. Little hint, pose the character then put the clothes on. If you find your character has parts of the body sticking through, double click on that body part and choose the invisible box in the dialog that comes up. Hope that helps. Marque
SCORPIO-69 ( ) posted Mon, 09 July 2001 at 10:31 AM
yep it did help ,thx lot
