Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Dec 04 2:47 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
I remember that some parented props had to be re-parented before they would be visable. The only other thing that leaps to mind is that a new saved figure in PPP makes a OBJ in the same dir as the figure and if the OBJ is moved , or the folder is re-named the figure does what you describe ( I had that happen to a few eve V3 modles i saved. This likley has nada to do with your problem , but it is the closes thing i have seen
Attached Link: http://www.runtimedna.com
Got a conformer that works fine in ppp whn I try it in 4.03 click on the cr2 and the damned thing wont appear , no figue present checked the cr2 for instilation all is fine , no hidden geomitries no prop replacemnet , version line is correct any ideas?
