Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
heyas; if the cr2 points to an obj, you can change the obj and delete the geometry rsr to reload the same cr2. or, save your remapped obj as a new obj and make a copy of the cr2 that points to the new obj. if the cr2 has any embedded geometry, changing the obj and/or obj pointers will have no effect, because the geometry is stuck in the library file. (you can tell if you have embedded geometry by doing a text search for geomCustom.)
Bloodsong, That's what I'm trying to do but it's not working on the Vampirella Costume? I remapped the origonal OBJ and saved as a new name, then edited the origonal CR2 to point to the new 'mapped' OBJ but when I load the edited CR2 it won't pick up the map?? I just searched for "geomCustom" and there ain't none....I'm jinxed ;-( Has anyone else mapped any of Ghastly's stuff? What could I be doing wrong?
Particulary, Ghastly's files; can I map and replace just the Geometries OBJ or do I have to make a full new CR2?
