Fri, Jan 10, 11:43 PM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Dec 04 2:47 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: Geometry Switching nightmares!!!!
Ladyfyre-graphics ( ) posted Mon, 24 September 2001 at 3:35 PM ยท edited Wed, 07 August 2024 at 12:26 PM
I've been working on a geometry switching prop, and apart from one little matter have just about got it sorted.....now I'm in danger of loosing my sanity LOL! Basicaly the whole thing works, comes in attached to it's parent, but lower than it should be, although if I go to edit, restore figure it corrects itself. I've no idea what is causing it as the actual .objs are all in the right places - I've checked several times! Does anyone have a clue as to what is going on here please before I either go mad or throw my pc out of the window?
www.ladyfyre-graphics.com
  • Poser freebies, tutorials and articles, gallery and lots of stuffage for the Poser and Daz|Studio Horses!
bloodsong ( ) posted Mon, 24 September 2001 at 5:21 PM
heyas; it sounds as if its init values are different from its memorized values. did you try hitting 'restore figure' then re-saving the prop? btw, as a side note, i want to mention that using swapping geometry in props is considered rather dangerous. ;)
Ladyfyre-graphics ( ) posted Mon, 24 September 2001 at 6:17 PM
Thanks Bloodsong that worked a treat, although I had to re-add the main object in CR2Editor, as it deleted it for some reason. Only thing is now I've been doing some test renders with it and switching through the dials quite a lot, and it just stops working for some reason - see what you mean about it being considered dangerous g Is this normal, or will I have to change it into a conforming figure to work? There's only one body part involved, as it is a set of 7 earrings for Victoria. Alla
bloodsong ( ) posted Tue, 25 September 2001 at 7:02 PM
heyas; hmmm... i really dont know, i never messed with the switching props after they told me not to ;) you dont need to make it a conforming figure, not if it is just one body part. you can just make it a one-body part figure, and name the part earrings, if you like (instead of 'head.') the only problem is, you can't get figures to remember their parents like you can with smart props. so... hmm, maybe it'd have to be conforming, after all. im not sure, sorry :/
Ladyfyre-graphics ( ) posted Tue, 25 September 2001 at 8:19 PM
Thanks, I'll have another play with it in the morning and try to make it conforming (keep your fingers crossed for me LOL!)
bloodsong ( ) posted Wed, 26 September 2001 at 5:49 PM
you will!? ::runs and HIDES:: ;)
Ladyfyre-graphics ( ) posted Wed, 26 September 2001 at 7:04 PM
Please pass me the Advil first then
