Sun, Jan 5, 4:19 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Visit the Carrara Gallery here.
Carrara Free Stuff here.
Visit the Renderosity MarketPlace - Your source for digital art content!
Subject: Help with Vertex Model?
willf ( ) posted Sat, 29 September 2001 at 1:35 AM · edited Fri, 19 July 2024 at 7:22 AM
This is the first vertex model that I've made even though I started with RayDream3! I can't seem to get the hands slit area to map light correctly, any suggestions on what I've done wrong? If not, I'll just fix in postwork as it will be quicker. My last resort is to change which finger is extended & move on to something else. Thanks willf
Miss Nancy ( ) posted Sat, 29 September 2001 at 2:18 PM
it looks like the hand slit normals need to be flipped
willf ( ) posted Sat, 29 September 2001 at 2:37 PM
That's what I thought but couldn't find a "flip normals" widget in the menu. Thanks
litst ( ) posted Sat, 29 September 2001 at 6:55 PM
That comes probably from the soft shadows settings : lower the bias and see if it helps . litst
willf ( ) posted Sat, 29 September 2001 at 7:16 PM
OK, I fixed it. Turned out that I didn't have the vertices linked properly. That's what happens when you rely on one modeler to do all your work and ahy the polymesh thingy was grayed out. Could have done this with a Spline model but would require way to much effort. Thanks again for the response.
