Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
That's the way Poser works. If the animation was done using the "hip" of the figure, then you can fix yours by adjusting the "body" instead, so that he is on the ground. Ctl-D adjusts the hip. [Of course, if the proportions of the dwarf are different than the original model used, he may not stay on the ground as the pose changes...]
First,
Make sure the "Body" is selected
(shown below pic ---> "Figure 1" -----> "Body")
Now, On the "Window" menu ...
Open the "Graph" window
The upper right hand corner of the "graph" window shows which parameter is being displayed.
Click in the small triangle to pull down a list of the params and select ------> "yTran" ...
Look at the graph and see if there are any "key frames" after frame 1 that changes the "yTran".
If there are, delete all the "key frames" AFTER Frame 1 (which has the correct position that you want)
Now selet the "Hip" and repeat the above process
(shown below pic ---> "Figure 1" -----> "Hip")
cheers,
dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: Explorations v5
Hello.. I have a few questions regarding Poser4. I have Poser4 and I downloaded and installed the update 4.01 (I think) - It was the first update by CuriousLabs. In any case are there any new updates other than that one? What is Poser Pro Pack? I am asking for information on updates because of a technical problem I'm having. I have a Poser figure that is a dwarf. And whenever I apply an animation to him, he lifts off the gound. (Because the original Pose was created on a figure larger than a dwarf.) In anycase, I can fix the problem by hitting Ctrl+D on all the frames. I wanted to know if there was a fix for this. Either to load the Poser correctly, or apply the Ctrl+D to all frames in one motion? Any help would be appreciated.
