Tue, Dec 24, 11:21 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 7:38 pm)
Subject: Help!
MoxieGraphix ( ) posted Sun, 06 January 2002 at 12:05 PM ยท edited Sun, 04 August 2024 at 6:08 AM
Sorry if someone else has asked this question before, I rarely read the forums. I'm having problems with Poser (I'm running the Pro Pack). I am trying to set up a simple scene. It only has one figure (Vicky 1), a simple prop, and a hair figure. So far so good. I am attempting to apply a pose to her and when I try to select the pose folder I want, it jumps to a totally DIFFERENT pose folder. The folder I want starts with a "y", it opens a folder that starts with an "a". I don't know what to do. I tried closing poser and reopening it and it doesn't seem to work. Ideas?
ScottA ( ) posted Sun, 06 January 2002 at 12:43 PM
The library pallete in Poser can be a little flakey. The best way to select things from it is to click on the "Poses" button. Then click on the arrow pointing down while holding your mouse button down as you scroll through the various poses. Don't let up your mouse button until you highlight the exact pose you want. Give that shot. ScottA
ronknights ( ) posted Sun, 06 January 2002 at 1:39 PM
I had that problem with the "regular" version of Poser. In my case I think it was because I had way too many pose folders. It seems Poser can only handle so much, then you start seeing the names of categories/items listed in 4-5 (or even less) characters. Then you're bound to have several items which start out with the same few letters. That's when things to flakey. My only solution was to basically install all over again, and then make up my mind not to install too much. Poser should be able to handle anything you give it, not flake out on you like that.
