Thu, Jan 9, 4:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 3:46 am)
Subject: Characters Problem
arrow1 ( ) posted Mon, 07 January 2002 at 2:52 AM · edited Mon, 25 November 2024 at 11:43 PM
Many thanks to Little Dragon,Thgeisel and Nance for your promp reply to New User Same old problem.I have tried all of your suggestions but I don't seem to be getting any further. I downloaded edipadlite and tried that,all it does is tells what I already know.I will put this scenario to whoever would like to assist. We have a file we will say for example a girls name (Marianne). She is downloaded as a zip.I unzip the file into Poser,in order to do that I have to create a new folder called Marianne.I open windows explorer, I go to my path ,say C:/Program Files/Metacreations/Poser/ Marianne.I double click on this file and I get a runtime folder and I open. I click on this and I get a choice of Libraries and Textures.I click Libraries I get say George (where the file came from)and I get Marianne cr2 and rsr files.I highlite these and cut and paste them into Characters female.In order to return to textures I delete George and Libraries to get textures.I then click on textures and I get runtime , George, Textures. I then Go into the far column ,from top to bottom I get, minibump jpg,minitex jpg,ponytrans tiff ,Tshirt1 jpeg and Tshirt trans jpeg.I then create a folder in Textures called Marianne and cut and paste them to this file.If there is an obj I then open it up geometries and it will have a folder called Runtime/George/Marianne/obj.I then have to delete runtime and George to get a Marianne file to put the OBJ in.This is what I am doing and it is obviously wrong.Can anyone correct me. Cheers Arrow1.
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
leather-guy ( ) posted Mon, 07 January 2002 at 5:04 AM
Arrow1 Your description is pretty detailed - thanks for that as it really helps to visualize the problem as a whole. You're working too hard, actually. I always unzip into a D:Temp folder with stuffit expander, which also maintains the directory structure. The unzipped folder will normally have a Runtime folder. Sometimes it's nested a few layers deep, sometimes right on top. In Windows Explorer, I RIGHT-CLICK on this Runtime folder, and drag it into my Poser4 folder, where my "real" runtime folder is and click "Move to" in the pop-up menu that appears when I release the button there. This usually gives me an error message that there's already a runtime folder there. I click okay, that it's not a mistake, ("yes to all" button) and all the files and folders are transferred properly into poser's folder structure. Start poser, find the figure, & make sure it loads all right. This works for me 99.2% of the time. That's the basic method. Before transferring, I usually read the ReadMe in case of some wierd peculiarities, like needing another product installed first before the new one will load properly into poser (if it's a Victoria character, it won't load unless I already have Victoria installed, Some superheroes from 3D-CC won't load unless certain boots or capes from another artist are already installed, some characters are distrib with a pcb that needs to be decoded/installed instead of a real OBJ in the geometries folder, etc. etc. etc. ...), and I also look over the contents of any texture folders, looking for anything like BlablablaBUM.jpg, convert it into a bmp file, and rename the bmp to bum so poser won't choke on it, but that's just my preference. Later, when I'm sure the character loads okay, I may re-arrange the cr2's, hr2's, pz2's, etc into my existing folder structure, but then I always COPY it first, & make sure it loads okay from there before deleting the original folder. I have downloaded characters that were actually hard-coded to only open if the CR2 was in a specific folder, but those were older P3-based files, & I've never seen it in anything new. Hope I understood you trouble correctly, And that my comments help you. . . Good Luck!
