Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 06 11:12 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
It looks from the message above that you found it but if you use Morph manager you just click on BODY properties and you'll see the full body morphs. I believe full body morphs are just an invisible command to tell the individual morphs what setting to apply. They are not recorded in the cr2 as a new set of #s because that would be redundant. The 'math' as you put it, the morph coordinates, are under each body part.
"Your work is to keep cranking the flywheel that turns the gears
that spin the belt in the engine of belief that keeps you and your
desk in midair."
Annie Dillard
Looking through the Vicky 2 Cr2 I'm left wondering..where exactly is the unique information located for each full body morph? It's certainly not under "Body"! Each full body morph should contain the math and instructions for which morph that comprises it. This should amount to something that can be seen in a cr2. As far as I can tell, it's nowhere to be found. Is it done with little elves? Sorcery? Please help! -WTB
