Mon, Nov 11, 12:55 AM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 02 8:21 pm)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: 3DS file into poser
Oarman ( ) posted Sat, 02 February 2002 at 9:52 PM · edited Fri, 09 August 2024 at 10:40 PM
Im trying to export my 3DS file into poser in order to create a poser figure I can animate. Im using Studio Max 4.0 and I installed the MaxToObj plug-in. I did this because I needed to keep the group names when I imported the 3DS figure into Poser (PPP). The 3DS looked fined (Color was correct) but using the Poser Group tool without the original Group/parts name is not doable (and I need this to assign to the bones etc.). So I went the OBJ way. After I figured out how to flip the Z axis to Y (3DS to OBJ issue) my next problem was keeping my colors. I expect this not to be a problem because OBJ has a MTL file that should do the trick but no. I must not be doing something right. I need some help (or tutorial) on how I can keep my colors in my OBJ figure. Thanks Oarman
SAMS3D ( ) posted Sun, 03 February 2002 at 5:05 AM
Attached Link: http://www.sams3d.com/Tutorial.htm
Maybe my tutorial will help you, this always seems the best way to create a poseable figure, which is what it is called, not a prop. A prop does not have articulate parts. Download my tutorial. Sharen
HandspanStudios ( ) posted Sun, 03 February 2002 at 8:32 AM
Another thing that you can do, just to fix the problem of Poser's group tool being nearly useless, is get UV Mapper from free stuff. UV mapper can see materials and groups if they are there, that is if you exported them successfully. You can use uv mapper to assign a material to a group or vice versa. It's very handy for fixing the uv map problems that Max always seems to have in the exports too.
"Your work is to keep cranking the flywheel that turns the gears that spin the belt in the engine of belief that keeps you and your desk in midair."
Annie Dillard
