Sun, Nov 10, 4:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 3:47 pm)
Subject: importing into Poser ???
cmjackson ( ) posted Sun, 03 February 2002 at 2:27 PM ยท edited Sat, 02 November 2024 at 1:53 PM
If i create an object (eg: cylinder) in Bryce 4 how would i import it into Poser 4, and what format would i save it in?
SAMS3D ( ) posted Sun, 03 February 2002 at 3:12 PM
You can save it as a 3ds and import it as a 3ds, then export it out if you want as any of the exports Poser allows. Sharen
thgeisel ( ) posted Sun, 03 February 2002 at 3:13 PM
first :there is a cylinder in poser itself. The problem is that you cant export things you modelled in bryce( specially things done with bool operation).they only work in bryce. the best for exporting from bryce to poser is wavefront *.obj. first: select the thing you want to export, than click "e" in the small menue beside the object,than hit"Ctrl D" and you get the export window,than choose wavefront *obj
SAMS3D ( ) posted Sun, 03 February 2002 at 3:16 PM
Actually, you can export some things from Bryce, you do it from the edit window. Sharen
raven ( ) posted Sun, 03 February 2002 at 3:45 PM
The only native Bryce things you can export are terrains and lattices. Objects made using Bryce primitives can not be exported. Some objects imported into Bryce can be exported as other formats by the method mentioned by thgeisel above.
