Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
Since you can run the script at all, you must have some version of PPP, and you're basically doing the right things. I'm pretty sure the Random module was there from the start, not just in the later 'service pack' releases. It should be located at: .....Poser/Runtime/Python/Lib/random.py That folder should contain a large collection of .py files, which are native parts of the Python system. If it's not there, try reinstalling the PPP release in case your directory structure has been changed or 'simplified'. (I did that once, thinking the various .py files were just accessories, not necessities!)
My python page
My ShareCG freebies
![file_269483.txt](https://live.cdn.renderosity.com/forum/_legacy/file_269483.txt)
Last night somebody asked for an eye-blink script. I made that, but then decided to mix it in with my previous "squirm" script. The result is a "naturalizer", which creates a full range of natural wiggles and blinks so that an inactive character will appear to be alive instead of frozen. As with the previous versions, you should set up your frame count and timing first; then select each figure; then activate the Naturalizer for each figure separately. In the upper part of the script you can change several parameters, to make one character more nervous or twitchy than another. Rename the Message*****.TXT to NATURALIZER.PY before using.My python page
My ShareCG freebies
