Fri, Jan 10, 4:38 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: WIP, kinda like mad max, i need some props
pimpinwillye ( ) posted Fri, 05 April 2002 at 3:48 AM ยท edited Fri, 10 January 2025 at 4:30 PM
This is a scene i'm working on at the moment and i really need some blown up buildings and rubble for the background anyone know where i can get some, i got the ones at the baument site but i can't texture then and they have a really low polygon count. Thanx in advance
TygerCub ( ) posted Fri, 05 April 2002 at 5:03 AM
You can texture the baument stuff, but it takes work: 1) import the items into Poser, 2) then export as an object. 3) import into UV mapper 4) "save model" 5) "save texturemap" 6) import texturemap into paint program at a high resolution 7) reimport the object into Poser & add high resolution map That should work for ya. Good luck! If all else fails, find a good photo to paste on the background. It won't have to have buildings in it; just find some nice desert scene with a cool sky. That should work too.
Little_Dragon ( ) posted Fri, 05 April 2002 at 5:51 PM
KenS also has a couple of items at Chemical Studios. Look in 3D Models under the Miscellaneous sections for brokenwall, brokenwall2, and targetingwall.
pimpinwillye ( ) posted Fri, 05 April 2002 at 7:29 PM
Thanx, i've started texturing the baument models and the CS stuff will be excellent. Thanx Again
