Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 4:13 pm)
Attached Link: http://mine.site.ne.jp/dld/column/010419.html
Hi William, Karl's correct. Recently someone else was asking about transparencies and highlights in this thread http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=680172 I came across this in minerva's Digital Love Doll site (see link) about a year ago. Have a look at the pictures and the download and you'll get the idea. If you need to, run the page through Excite's Japanese site translator. It's a great idea though and can come in useful for many effects and not just with the catsuit. Thanks for the tip :)Not bad, not bad at all...
What I did once, just as a temporary measure, is to take an image and open it in my fave photo editor (you guys use p-shop, I use GIMP... same-same, as long as it handles layers.)
I slap on a transparent layer, then monkey with that layer to do what I will. I then save the results as a seperate .tif file (I have Pro Pack, so this is no prob... otherwise I think you have to save it in .jpg... not sure on that part.)
Before closing the editor, I copy off a seperate image of my new layer, and turn it to B&W coloring, then run it through the negative filter, which gives me a bump map if I need it.
Fire up Poser, then use your modified texture, and the bump map if desired... et voila' - a bit more work, but less work than getting a catsuit to stay conformed ;)
/P
