Sun, Jan 26, 3:39 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 26 2:05 pm)
Subject: how do i change resolution in avi?
raz ( ) posted Wed, 15 May 2002 at 1:35 AM ยท edited Tue, 26 November 2024 at 2:27 AM
the default "max" res for an AVI is only 640 X 480. anyone figure out how to (if possible) change this to higher res? and stay that way as the default "max" res?
Little_Dragon ( ) posted Wed, 15 May 2002 at 1:48 AM
In the Animation menu, select Animation Setup. Enter your desired res in Frame Width and Height. I'm not sure how you could change that to the default resolution. Maybe if you click the Set Preferred State button in the General Preferences panel (Edit menu) ....
aleks ( ) posted Wed, 15 May 2002 at 2:49 AM
in 3dsmax.ini (you can open it with a notebook) you'll find line like this: [PresetOutputSize3] PresetWidth=640 PresetHeight=480 type in your desired size!
