Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
The new texture is smaller and to the side of the areas it should be example: the face of the redered man and the face of the texture are sidce by side and the new tex. is smaller than the man? I'd give a pic but I don't have it anymore :( Have to make another one :(
Insanity is a waking state...Darkness is a being...Want To Play.........heheheheh
kinda, sorta but not quite. the template when doctored looks correct it's when it is applied to the figure that it appears to have a ghost image besides the normal images. you will see the eyes where they are on the figure then very faintly you see the eyes positioned to the side a bit further. like a ghost image of the person superimposed off centered. confused yet?
Sounds like your texture map isn't completely lined up, plus you've got color assigned to the materials (iris, pupil, lips, etc) and you're seeing both. When you apply a texture, you usually want the object colors for the materials to be set to white, so the texture shows through accurately. Then you need to get your texture lined up with the template. HTH - Elisa/gryffnn
I know there are several textures on how to do skin out there but I just have one problem. I've opened up my P4 male template and from scratch made a skin texture. The problem is "why won't it wrap on my P4 man right. I did use the P4 man's template. Any ideas :) Thanks.
