Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Morgan, Yes, each part of the body may be scale in x,y,z or in whole. So you can scale the index longer and thinner if you like. If you at the dials on your screen, you should see scale, xscale, yscale, zscale they used to do this. I hope this helps thebert
The difference between stupidity and genius is that genius has its limits.
bushi, that would be a groove...it sounds like exactly the sort of thing I was thinking of...just to be certain I'm not mistaking your meaning, you're saying this would be a single slider that could for instance proportionately change the existing scale settings for hands and fingers as though they were a single unit?...crossing my fingers, sure hope so.
Yes, it would display a panel with all the parts of the current figure. You could then select the parts to use and that would link all of selected parts to a single slider bar. Changing the value on the slider would change the scaling of all the selected parts. Thinking about it a bit more, it would probably work better if it where have 4 sliders. One each for scale, x-scale, y-scale and z-scale but the idea would be the same. Select the parts and their scaling values would all be changed from the 4 slider bars.
Seems you could make a pose file that would set scales for a series of body parts, such as fingers. Have to do it in a text editor, but then it would work on any figure with those part names. It would have a set percentage, not Bushi's elegant sliders to adjust on the fly, but would be useful if you wanted to do the same scaling more than once. Hopping into a text editor to change the percent would still be faster than adjusting each finger segment. I'd give it a try, but I've got to get a project out the door - Elisa/gryffnn
This is likely a remarkably foolish question, but is it possible when working on a figure in Poser to increase or decrease the scale of more than one body part simultaneously? I am thinking particularly of hands and their corresponding fingers, that it would be useful to change the scales of fingers proportionately with changes to the hands they are on. Can this be done, or must one work individually with each finger segment once the hand scale has been modified? Peace, Morgan
