Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
You might be able to customize and rename a .lt2 file and store it in your library. each light should either have a standard name like light1 etc. for ease of reference to delete later, or a unique name if you don't want to delete the unique light. Note: when you change lights any extra lights will be blacked out. You might check archives under "lights". Something in last couple of months I'm sure. (Procedure is similar to creating MOR files.) Perhaps the easiest way to go is to save your lights to the lights library within poser. Only use the other procedures when saving lights to the light library won't work. Greg: are you using this for animation? there's more to it if so . . .
I've never figured out how to completely reset/remove lights in Poser 4. Did a search for topics, and found a utility for the PRopack, which I don't have. For a few lights, its no big deal to manually select/delete, but these great "lighting environment" have more than 20-lights. I tried deleting all lights, and saved that as a setup. But when I apply that setup, it just dims the lights, doesn't delete them. I want to get rid of them entirely. Any ideas, workarounds?
