Tue, Feb 4, 4:08 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 03 12:46 am)
Subject: poser problem with michael 2
wrpspeed ( ) posted Tue, 23 July 2002 at 9:32 PM ยท edited Fri, 31 January 2025 at 3:32 PM
hi, I have been having a problem with Michael 2(multiple figures). I load one figure (correctly and intact) and when I load the second Michael 2, the hip area is transparent(I checked properties and it should be visible). it also occurs on massive mike and muscular mike but not on Michael 1. I am running xp on a Pentium 4 with 384mg of ram. any info would be appreciated. thanks terry.
djuke ( ) posted Wed, 24 July 2002 at 3:00 AM
I had the same problem until ernyoka1 solved it for me. :-) Go to the figure option and turn the genitial on and then back to off, or the other way around. That should do the trick.
eirian ( ) posted Wed, 24 July 2002 at 5:07 AM
It doesn't always work, tho. I've had the same problem and solved it by deleting the RSR from the geometries folder. I also found it doesn't happen if I load the figure with genetalia ON. Only if gen is switched off first. Weird but common problem...
wrpspeed ( ) posted Wed, 24 July 2002 at 1:53 PM
i think i solved it. part of the problem was that i was getting short of hard drive space in the past so i changed the virtual memory (reduced it). i reset the virtual memory to let my computer decide and then i was able to load at least 3 michael2's with no problem at all. thanks for all that answered.
