Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 3:46 am)
try intensity of overhead higher ( 100%) and scale it higher also, then no other light source lower than 50%, the fire settings ( need four lights there) should not be much lower than the overhead settings. poser 4 does not have infinite light abilities. ( try downloading vue desprit 4 trial version and importing the scene into it ) vue has infinit lighting and also has point lights, which are great for the candle lights.
Jaqui, Thank you for your quick response. I have tried altering the intensities, to no avail. I have even tried altering some of the settings for the spots, but none - so far - have "realistically" rendered the lighting. I understand that I will need more spots for the candles, as I only have one per wall to "emulate" the light coming from the walls and not the individual candles. I figure once I get the per wall settings straight, the four candles would be easier. Poser 4, at least with the Pro Pack, only has Infinite or Spot lights: * Infinite emulates sunlight, in that it is parallel light to the scene and lights all charatcters/props the same. * Spots allow you to direct the light from a given point outward. I will most likely try Vue sooner or later, but I would like to see if I can stick with Poser at the moment. My brain only has a limited capability to grasp any number of things at once. ;0) Thanks again! I do appreciate it.
Your problem is in the render settings of course ! Go to render>Render options. then you will get a little screen to the right of the disalog box is 4 check boxes. bottom one says something like render shadows or sumtin about shadows. !?! TURN THAT BOX OFF!?! as in no check box. also check the anit-alias for better render picture. problem solved... tell me if its still messed up.
Try also to play around with the shadow dials on the lights. They are set to 100% by default, but since Poser lacks ray tracing (until Poser 5...) and other fancy rendering features, all shadows will get very dark. Real life shadows are very seldom totally dark, there will always be light reflected from surrounding areas. Judging from the last render, the scene might benefit from a shadow setting of less that 100% in order to brighten up the areas in shadow.
Content Advisory! This message contains violence
I just recently got Poser 4 and the Pro Pack and decided to progressively teach myself how to use it. So far, I think I have done well going from "cartoonish" figures of myself and friends to an almost "photo realistic" render (with Photoshop 6 touch-ups). Now I am to the point of trying to complete a full scene, and I am running into a little difficulty. For no sane reason, I decided to choose making a render of Lizzy Borden's bedroom (my interpretation of course) for my first scene. The scene, as I have it setup now, is depicted in the attached screenshot. (If you see your props/pose in there, thanks for letting us use them!) I currently have four spotlights set up: 1) Overhead: Simulate the overhead chandelier. 2) Front: Simulate the wall-mounted candles in front. 3) Back: Simulate the wall-mounted candles in back. 4) Fireplace: Simulate the fireplace. (Hidden in front.) As you can see in the screenshot, I have managed to position the spotlights in the respective locations. I overlayed them with white rounded rectangles to make them stand out more. I have also tried fiddling with the individual light properties based upon how I feel the scene would naturally be lit. (Ie, the most light coming down from the chandelier, next brightest would be the fireplace, followed by the wall-mounted candles.) I even fiddled with the light colors and other properties trying to simulate the fire light vs regular white light. The main problem comes from trying to find the perfect lighting setup to simulate four sources of "fire-based" light. It seems that regardless of how I set up the spotlights, unless I have an "infinite" light setup, the scene renders way too dark, almost to the point of not being able to see any detail at all. The system I am running this on is a custom built, and it is getting "old", so I am sure that has a bearing: AMD 800MHz T-Bird, 512MB PC133 DIMM, GeForce2 64MB AGP card with nVidia drivers, 40GB HDD, Windows 98SE, etc. I have noticed that at times, it seriously lags when rendering, to the point that it almost seems like the system is hanging. I have been looking for a reason to "justify" a new system, and I think I found one. :0) If anyone has run into a similar situation or knows of an adequate work-around, I would appreciate it. I do not want to "fudge it", because that will circumvent the learning process and I will still have the same gap if the situation arises again. Thanks in advance.
