Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 7:39 am)
Use the "export" function. 1. When you see the list of all the object in the studio, 2. UNCHECK the "Universe" to deselect everything and then, 3. put an "x" in the square boxes for the items you want to save as a single prop. 4. "Export" to whatever filename you want to use. 5. "Import" the item you just exported. Now, it is ONE object. Make sure all the parameters are correct, i.e., texture maps, colors, origin, name, etc. Save your new combined prop to the library. And that's all there is to it! ;=] cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
That wall is something else....I have a few ideas for that ;) Are you going to make it available?
Remember...getting lost is the senic route to the eventual destination. (And a lot prettier than the straight road)
NOTE: both dr. geep's and Jeff's solutions are useful in different situations. Jeff's "subset" approach creates a library entry that loads back in as TWO independent props. Dr. Geep's "Export" approach (I assume he's referrring to "Export/Wavefront OBJ") creates ONE prop object - at the cost of having the new OBJ file for you to put somewhere in Geometries. -- Steve
