Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 9:45 pm)
Thanks everyone for the feedback! It sounds like XP Home edition will meet my needs, though I want to know more about Pro's Backup utility and ASR that MeInOhio mentioned. Also, hmatienzo, could you tell me how much better Pro is than Home in terms of compatibility and stability? Is there software that you have used that functions better under Pro than Home? Thanks again! Jay PS In case anyone's interested, I am getting a new system. I am VERY excited about it. I try to be frugal and not upgrade too often, so when I do, it always feels like Christmas. I have been using Windows 98 with a 700 megahertz Pentium 2 and 255 megabytes of RAM. It looks like I will be buying a Dell running XP with a 2.5 megahertz Pentium 4 and a gig of RAM. Quite a jump. Did I mention I am really excited about this? :)
I have a book called WindowsXP Inside Out which tells you how to use the Backup Utility and what it can and can't do. It's a good book. The backup utility is in a folder on the Home edition. It is not part of the default installation in the Home edition. And the book says that it's a little confusing as far as how the Backup is implemented in the Home edition. They say that the Home edition will let you create a ASR set, but there is no way to restore it, if you need it. For that you need the Pro version. You can use the backup utility to do general backups on both versions. I've used the ASR wizard in the Pro version, but I've never had to restore yet---thankfully. I guess you have to put the windows disk in and boot up and press f2 at some point and follow the instructions to restore. I just got Ghost2003. It allows me to create a drive image to an NTFS drive and you're suppose to be able write on to a firewire or usb drive as well, although I haven't got that part to work yet. (None of the earlier versions of Ghost can do this.) Ghost won't let you make incremental backups however. It's either all or nothing. If you want to know anything else, I'll fill you in on what I know. I've also tried Backup MyPC and DriveImage so I can tell what I like and don't like about each of them. Except for DriveImage. I couldn't get that one to work at all. It told me I had a CRC image and failed everytime I tried to run it. I ran a low level scan like it said, but no errors were reported and Ghost 2003 and windows Backup both run fine, so I think it's something about that program and XP.
I am just curious if there is any advantage of using XP Professional over XP Home with either Poser 4 or 5. Also, is XP Professional that much more useful over XP Home for uses other than Poser. I know this was discussed exhaustively some time back, but I don't remember the verdict. Thanks for the help! Jay
