Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 7:39 am)
To do this in Poser, you need to make up a texture and trans map for the window in a paint program. When making transmaps, keep in mind the transmap is greyscale of your texture, but with the areas you want to show up painted white. Areas painted black will render transparent. Use shades of gray for varying degrees of transparency. You will have to set transparency to 100% and you may also have to adjust the transparency min and fallout values. Getting good transparencys is not always easy, because how you set up the lighting makes a difference and so does making sure that you use true black 0,0,0 otherwise 100% transparent areas will show. Will take some trial and error, but you can do it. :O)
