Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
One problem with saving body rotations, you will be changing the location that the body is placed by the artist. The best method is to not move the body from the standard location for poses and do all rotations using the hip. Now if this is a pose set to fit a scene (like a guy sitting on that stool at the bar) you will have to add the changes to the pose file for the body. This is the only instance where the body should be moved from it's standard location.
You can't save BODY rotations or translations from within the Poser4 interface, but you can add them by hand with a text editor. Add a BODY actor to the pz2 just above the hip actor, leave the key values for channels you don't want to affect blank, or leave those channels out all together. Thus the statement that "One problem with saving body rotations, you will be changing the location that the body is placed by the artist." is incorect, as you can change the rotations without affecting the location.
Below is an example of a partial pose file that will rotate the BODY 90 degrees Y, and the hip 20 degrees X. You can cut it out, save it with a pz2 extension, and experiment, changing the values or adding and deleting channels. This is just an example of a partial pose file, but you should be able to see how it could be applied to a full pose file by copying the BODY section over.
version
number
actor BODY
channels
rotateY yrot
keys
k 0 90
actor hip
channels
rotateX xrot
keys
k 0 20
figure
P.S. saving this in a format that you can cut and paste has removed the indentation, but this will not effect the operation of the file.
You can also use the free utilities Mat Pose Edit v2.0.2, or Morph Manager v4, to extract pose data (including BODY) from a cr2 file. but I suggest you will find it easier (though probably slower) to do it in a text editor as in post #6, until you get a bit of practice and understanding of what you are doing.
When saving a pose, is it possible to include the overall body rotation in the pz2? If so, how? g I have opened the pz2 and there seems to be no reference for the overall body positioning, so on the surface it doesn't seem possible. I throw myself on the mercy of the poser gurus here. Please help! Many thanks.
