Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Can you be more specific? Do you want puddles, is it streaky, is the runway bumpy, are we going to be taking a picture of the image at the surface of the runway or a ways off? As a first shot given I'm not sure what we're doing just yet, I'd put two kinds of patterns in the color channel mixed with turbulence. One pattern would be asphalt, the other would be your water. Then I'd copy the same mixer into the reflection channel and mix different values until the "puddle" look was where you wanted it. This is just a first crack at it. Give us some more detail and we'll soak you! -Kix
-Kix
Attached Link: http://www.neilblevins.com/cg_education/wet_materials/wet_materials.htm
What you want to do is to use a specularity map, meaning a map in the highlight channel. I found a place in the web with a good tutorial.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I'm trying to create a "wet" surface for a runway - anyone have any ideas about to use the shader trees to get a realistic effect?
