Tue, Feb 18, 4:50 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: Geometry-Swapping Dials
scupper ( ) posted Thu, 12 December 2002 at 5:40 PM · edited Mon, 03 February 2025 at 5:05 PM
Is there a tutorial or discussion somewhere on setting up Geometry-Swapping dials, such as those found on the Mike/Vicky Changing Fantasy Suits or the Spywear set from DAZ? A link would be appreciated.
JeffH ( ) posted Thu, 12 December 2002 at 6:14 PM
Yes, I have an old tutorial on the Yahoo Poser tech list. It's in the downloads section.
bloodsong ( ) posted Thu, 12 December 2002 at 6:18 PM
Attached Link: http://groups.yahoo.com/PoserTECH/
where's your link, jeff? :) (don't look at me, i never remember it!) okay, i guessed what it was. i'm usually wrong.
maclean ( ) posted Thu, 12 December 2002 at 6:40 PM
Funny, Jeff. I didn't realise you were Jeff Howarth from Poser Tech. Silly me. I still have a bunch of your tutes and tricks, like Dial-a-prop. mac
xenic101 ( ) posted Thu, 12 December 2002 at 9:45 PM
Hey! That links dead. Sound like some useful tuts. Anyone know where they are now. The link gives a 404 error. Tried a search for poser in the groups main. I stopped looking around 60 out of 270 this person is poser links.
ScottA ( ) posted Thu, 12 December 2002 at 10:17 PM
Attached Link: http://groups.yahoo.com/group/PoserTECH
You were pretty close bloodsong. This should be the correct Link.
JeffH ( ) posted Fri, 13 December 2002 at 2:49 PM
I wish dial-a-prop would work outside of Poser 4.03 - anyone tested the concept in P5?
bloodsong ( ) posted Fri, 13 December 2002 at 3:51 PM
thanks, scott. jeff, you always taught me that geom swapping in a prop was highly unreliable and not recommended. so i never use it in props. i always tell everybody else not to use it in props. hmmm... but maybe i'll have a chance to give it a try in p5 this weekend, and let you know what happens.
JeffH ( ) posted Fri, 13 December 2002 at 4:50 PM
Well yeah, I don't think it works in the Pro Pack and possibly not in P5 either.
ScottA ( ) posted Fri, 13 December 2002 at 5:37 PM
Jeff. It works OK in the ProPack. I don't have P4 installed by itself. But it crashes P5 badly. The mouse disappears and only Ctrl+Alt+Del gets you out. I was making my own Geometry swapping .pp2 and I forgot to add the last bit of special code in the channels section that goes like this: geomChan propGeom { uniqueInterp name prop type initValue 1 hidden 0 forceLimits 4 min 0 max 6 trackingScale 0.02 keys { static 0 k 0 1 } interpStyleLocked 1 The prop loaded fine and did not crash P5 until I added that block of code. Of course. The Geomswitching won't work without that block of code. But that's what I've seen so far. ScottA
wadams9 ( ) posted Fri, 13 December 2002 at 6:00 PM
So is that crash problem only with props? Figures okay?
ScottA ( ) posted Fri, 13 December 2002 at 7:05 PM
Yes. Geom swapping in figures seems to work ok in P5. They changed things a bit in P5 so you don't need to load a NULL if you have more than one ERC enabled item loaded into the same scene. That may have indirectly caused a problem with Geom swapping for props. ScottA
JeffH ( ) posted Fri, 13 December 2002 at 10:21 PM
Wish I had time to play with that stuff again. Thanks Scott.
ScottA ( ) posted Fri, 13 December 2002 at 10:46 PM
I wish I didn't. ;-)
